이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the laptop off and disconnect it from all power sources.
Turn the laptop over so that the bottom is facing upwards.
Slide the release latch while simultaneously pulling the battery outwards.
Once the battery has been removed, take out the two screws (3mm Phillips #1) beneath it. These screws hold the center control cover in place.
Flip the laptop back over to the front and push the screen open as far as possible.
Pry the center control cover off of the laptop using a plastic opening tool. On the right side of the cover, there is a small divot to help you start removing the cover.
Carefully lift the central control cover away from the laptop.
Lift the connector latch to remove the keyboard cable from the motherboard.
Lift the keyboard away from the laptop.
Lift the connector latch to remove the power button board from the motherboard.
Pry the power button board out with your finger.
Pull the power button board away from the laptop.
