주요 콘텐츠로 건너뛰기
Dell Inspiron 1545 USB Port Replacement
필요한 것
  1. Dell Inspiron 1545 USB Port Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 USB Port Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 USB Port Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 USB Port Replacement, Center Control Cover: 4 단계, 이미지 1개 중 1개
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 USB Port Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 USB Port Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 1545 USB Port Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 1545 USB Port Replacement: 6 단계, 이미지 3개 중 3개
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  7. Dell Inspiron 1545 USB Port Replacement, Base Cover: 7 단계, 이미지 1개 중 1개
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  8. Dell Inspiron 1545 USB Port Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 1545 USB Port Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully lift the base cover vertically away from the laptop.
  9. Dell Inspiron 1545 USB Port Replacement, CPU Heat Sink: 9 단계, 이미지 1개 중 1개
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  10. Dell Inspiron 1545 USB Port Replacement: 10 단계, 이미지 1개 중 1개
    • Pull up on the Heat Sink unit to remove it.
  11. Dell Inspiron 1545 USB Port Replacement, Optical Disk Drive: 11 단계, 이미지 1개 중 1개
    • Flip the laptop to its back side.
    • Remove the screw (5mm Phillips #1) that secures the Optical Disk Drive on the back of the laptop.
  12. Dell Inspiron 1545 USB Port Replacement: 12 단계, 이미지 3개 중 1개 Dell Inspiron 1545 USB Port Replacement: 12 단계, 이미지 3개 중 2개 Dell Inspiron 1545 USB Port Replacement: 12 단계, 이미지 3개 중 3개
    • Push the Optical Disk Drive out using a spudger tool as shown and pull from the front cover of the Optical Disk Drive.
  13. Dell Inspiron 1545 USB Port Replacement, Keyboard: 13 단계, 이미지 1개 중 1개
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  14. Dell Inspiron 1545 USB Port Replacement: 14 단계, 이미지 1개 중 1개
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  15. Dell Inspiron 1545 USB Port Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  16. Dell Inspiron 1545 USB Port Replacement: 16 단계, 이미지 1개 중 1개
    • Lift the keyboard up and away from the laptop.
  17. Dell Inspiron 1545 USB Port Replacement, Palm Rest: 17 단계, 이미지 1개 중 1개
    • Remove the 11 screws (5mm Phillips #1) from the back of the laptop as marked. One screw is in the middle, by the RAM.
  18. Dell Inspiron 1545 USB Port Replacement: 18 단계, 이미지 1개 중 1개
    • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
    • Unwind the wires from the routing guides.
  19. Dell Inspiron 1545 USB Port Replacement: 19 단계, 이미지 1개 중 1개
    • Turn the laptop back over to its normal resting position and pull the black and white wires previously connected to the WLAN through the hole.
    • Remove the 4 smaller screws (5mm Phillips #1) and one screw on the top left (3mm Phillips #1) from the palm rest.
  20. Dell Inspiron 1545 USB Port Replacement: 20 단계, 이미지 1개 중 1개
    • Disconnect the Bluetooth card cable, Wed cable, Camera1 cable, power cable, and touchpad cable from the respective Motherboard connectors as marked. For the Bluetooth cable and Camera1 cable, pull the plugs towards the screen. For the touchpad and power cable, lift the black tab and then pull them out. For the Wed cable, pull the blue tab up.
    • Unsecure the wires from the routing guides so they are loose.
    • Pull on the plastic tabs for each connector to help prevent causing damage to the connectors.
  21. Dell Inspiron 1545 USB Port Replacement: 21 단계, 이미지 1개 중 1개
    • To separate the palm rest from the rest of the computer, use a plastic opening tool to lift up the plastic. It is best to start at one point and work your way around.
  22. Dell Inspiron 1545 USB Port Replacement, Daughter Board: 22 단계, 이미지 1개 중 1개
    • Remove the 3 screws (3mm Phillips #1) that secure the daughter board to the motherboard.
    • Lift the daughter board away from the laptop.
  23. Dell Inspiron 1545 USB Port Replacement, Motherboard: 23 단계, 이미지 1개 중 1개
    • Remove the two screws (3mm, Phillips #1) on the left and the two screws (5mm, Phillips #1) on the right that secure the Motherboard to the laptop.
  24. Dell Inspiron 1545 USB Port Replacement: 24 단계, 이미지 1개 중 1개
    • Disconnect the Thermal Fan cable, Speaker cable, and USB Board cable from their connectors.
  25. Dell Inspiron 1545 USB Port Replacement: 25 단계, 이미지 1개 중 1개
    • To remove the Motherboard, pull away and up from the base of the laptop.
    • Along with removing the Motherboard if you haven’t already done so, the auxiliary port cover on the front will come off with it as well.
  26. Dell Inspiron 1545 USB Port Replacement, USB Port: 26 단계, 이미지 1개 중 1개
    • Remove the two screws (5mm, Phillips #1) in order to remove the main auxiliary board containing USB ports, and audio/microphone ports.
  27. Dell Inspiron 1545 USB Port Replacement: 27 단계, 이미지 1개 중 1개
    • There is another USB board on the right side of the laptop. To remove this simply remove the two screws (5mm, Phillips #1) and lift the port up.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathan Lemay
회원 가입일: 04/16/14
3,145 평판
안내서 15개를 작성함
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 회원
CPSU-REGAN-S14S9G14
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 6,270
