주요 콘텐츠로 건너뛰기
Dell Inspiron 1564 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: 1 단계, 이미지 1/2 Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: 1 단계, 이미지 2/2
    • Locate battery latch on bottom of computer and slide to right.
    • While holding battery latch, pull the battery away from device and the battery will come free.
  2. Dell Inspiron 1564 Hard Drive Replacement, Remove Bottom Cover Screws: 2 단계, 이미지 1/1
    • With a J0 screwdriver bit, loosen all screws from the backing above the battery latch and remove the covering.
  3. Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: 3 단계, 이미지 1/2 Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: 3 단계, 이미지 2/2
    • Locate the three 4mm screws securing the hard drive and unscrew them with a J0 screwdriver.
    • Slide the hard drive to the left to unplug the SATA data and SATA power cables, then gently pry upwards and pull the drive away from device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Megan Nelson
회원 가입일: 10/05/15
293 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,924
