주요 콘텐츠로 건너뛰기
Dell Inspiron 1564 Laptop Battery Replacement
필요한 것
  1. Dell Inspiron 1564 Laptop Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop on a flat surface and open the cover.
    • Unplug the power cord from the laptop.
  2. Dell Inspiron 1564 Laptop Battery Replacement: 2 단계, 이미지 1/1
    • Turn the laptop off by holding down the silver power button in the upper left corner until all the lights turn off.
    • If the laptop is not turned off, there is a risk of electrical shock when replacing the battery.
  3. Dell Inspiron 1564 Laptop Battery Replacement: 3 단계, 이미지 1/1
    • Close the cover of the laptop and turn the laptop over so the the bottom is facing up.
    • Locate the release latch.
    • Locate the battery on the bottom of the laptop.
  4. Dell Inspiron 1564 Laptop Battery Replacement: 4 단계, 이미지 1/1
    • Slide the battery release latch to the right and hold it.
    • With your other hand, pull the battery away from the laptop and release the latch.
    • Discard the old battery according to your local laws.
결론
- A new Dell Inspiron 1564 battery can be bought at www.laptopbatteryhq.com for about $30
다른 6명이 해당 안내서를 완성하였습니다.
Matthew Johnson
회원 가입일: 10/06/15
104 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 13,246
