주요 콘텐츠로 건너뛰기
Dell Inspiron 1564 Memory Module Replacement
  1. Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: 1 단계, 이미지 1/2 Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: 1 단계, 이미지 2/2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Dell Inspiron 1564 Memory Module Replacement, Remove the Memory Module: 2 단계, 이미지 1/1
    • Remove the memory module from the memory module connector.
  3. Dell Inspiron 1564 Memory Module Replacement, Align the Notch: 3 단계, 이미지 1/1
    • Align the notch in the memory module with the tab in the memory module connector.
  4. Dell Inspiron 1564 Memory Module Replacement, Sliding the Memory Module: 4 단계, 이미지 1/1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
결승점
Terrence15
회원 가입일: 12/18/17
79,121 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 240
