주요 콘텐츠로 건너뛰기
Dell Inspiron 1564 RAM Replacement
필요한 것
  1. Dell Inspiron 1564 RAM Replacement, RAM: 1 단계, 이미지 1/2 Dell Inspiron 1564 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: 2 단계, 이미지 1/1
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: 3 단계, 이미지 1/3 Dell Inspiron 1564 RAM Replacement: 3 단계, 이미지 2/3 Dell Inspiron 1564 RAM Replacement: 3 단계, 이미지 3/3
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
결론
Tyson Duerr
회원 가입일: 10/06/15
273 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 982
