주요 콘텐츠로 건너뛰기
Dell Inspiron 15R 5521 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15R 5521 Display Assembly Replacement, Peeling the Tape: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Peel the tape that secures the display cable to the system board.
  2. Dell Inspiron 15R 5521 Display Assembly Replacement, Disconnecting the Display Cable: 2 단계, 이미지 1개 중 1개
    • Disconnect the display cable from the connectors on the system board.
  3. Dell Inspiron 15R 5521 Display Assembly Replacement, Disconnect the Cables: 3 단계, 이미지 1개 중 1개
    • Disconnect the wireless mini-card cables from the connectors on the wireless mini-card.
  4. Dell Inspiron 15R 5521 Display Assembly Replacement, Moving the Port Cable: 4 단계, 이미지 1개 중 1개
    • Move aside the power adapter-port cable from the screws.
  5. Dell Inspiron 15R 5521 Display Assembly Replacement, Remove the Screws: 5 단계, 이미지 1개 중 1개
    • Remove the screws that secure the display assembly to the computer base.
  6. Dell Inspiron 15R 5521 Display Assembly Replacement, Lift the Display Assembly: 6 단계, 이미지 1개 중 1개
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 15R 5521 Display Assembly Replacement, Placing the Display Assembly: 7 단계, 이미지 1개 중 1개
    • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  8. Dell Inspiron 15R 5521 Display Assembly Replacement, Replace the Screws: 8 단계, 이미지 1개 중 1개
    • Replace the screws that secure the display assembly to the computer base.
  9. Dell Inspiron 15R 5521 Display Assembly Replacement, Connecting the Cables: 9 단계, 이미지 1개 중 1개
    • Connect the wireless mini-card cables to the connectors on the wireless mini-card.
  10. Dell Inspiron 15R 5521 Display Assembly Replacement, Connect the Display Cable: 10 단계, 이미지 1개 중 1개
    • Connect the display cable to the connector on the system board.
  11. Dell Inspiron 15R 5521 Display Assembly Replacement, Adhering the Tape: 11 단계, 이미지 1개 중 1개
    • Adhere the tape that secures the display cable to the system board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 711
