주요 콘텐츠로 건너뛰기
Dell Inspiron 15R 5537 DC Jack Replacement
필요한 것
  1. Dell Inspiron 15R 5537 DC Jack Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 DC Jack Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 2 단계, 이미지 3개 중 3개
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 DC Jack Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 DC Jack Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 4 단계, 이미지 3개 중 3개
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
  5. Dell Inspiron 15R 5537 DC Jack Replacement, Wi-Fi Module: 5 단계, 이미지 1개 중 1개
    • Once the keyboard is removed, the Wi-Fi module will be accessible.
  6. Dell Inspiron 15R 5537 DC Jack Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Use the opening tool to lift both antenna cables upward from the Wi-Fi module.
  7. Dell Inspiron 15R 5537 DC Jack Replacement: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 3mm Phillips #000 screw securing the Wi-Fi module.
    • Lift the Wi-Fi module up and out of the laptop.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  8. Dell Inspiron 15R 5537 DC Jack Replacement, Remove the Screws: 9 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive assembly to the computer base.
  9. Dell Inspiron 15R 5537 DC Jack Replacement, Sliding the Hard Drive Assembly: 10 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  10. Dell Inspiron 15R 5537 DC Jack Replacement, Lifting the Hard Drive Assembly: 11 단계, 이미지 1개 중 1개
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  11. Dell Inspiron 15R 5537 DC Jack Replacement, Remove the Screws: 12 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  12. Dell Inspiron 15R 5537 DC Jack Replacement, Lifting the Hard-Drive Bracket: 13 단계, 이미지 1개 중 1개
    • Lift the hard-drive bracket off the hard drive.
  13. Dell Inspiron 15R 5537 DC Jack Replacement, Align the Screw Holes: 14 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  14. Dell Inspiron 15R 5537 DC Jack Replacement, Replace the Screws: 15 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  15. Dell Inspiron 15R 5537 DC Jack Replacement, Placing the Hard Drive Assembly: 16 단계, 이미지 1개 중 1개
    • Slide and place the hard-drive assembly in the hard-drive bay.
  16. Dell Inspiron 15R 5537 DC Jack Replacement, Sliding the Hard-Drive Assembly: 17 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  17. Dell Inspiron 15R 5537 DC Jack Replacement, Replace the Screws: 18 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive assembly to the computer base.
  18. Dell Inspiron 15R 5537 DC Jack Replacement, Palm Rest: 19 단계, 이미지 1개 중 1개
    • Remove thirteen 5mm Phillips #000 screws from the back cover of the laptop.
  19. Dell Inspiron 15R 5537 DC Jack Replacement: 20 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 20 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 20 단계, 이미지 3개 중 3개
    • Use the opening tool to unplug the palm rest cables and slide the cables out.
  20. Dell Inspiron 15R 5537 DC Jack Replacement: 21 단계, 이미지 1개 중 1개
    • Remove seven 5mm Phillips #000 screws from the midframe.
  21. Dell Inspiron 15R 5537 DC Jack Replacement: 22 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 22 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 22 단계, 이미지 3개 중 3개
    • Use the opening tool to lift the edges of the palm rest. Once all of the sides are lifted, pull the palm rest off.
  22. Dell Inspiron 15R 5537 DC Jack Replacement, Display Assembly: 23 단계, 이미지 2개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement, Display Assembly: 23 단계, 이미지 2개 중 2개
    • Unplug the DC jack to the right of the fan.
  23. Dell Inspiron 15R 5537 DC Jack Replacement: 24 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 24 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 24 단계, 이미지 3개 중 3개
    • Unplug the display cable below the fan by pulling the cable straight back.
  24. Dell Inspiron 15R 5537 DC Jack Replacement: 25 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 25 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 25 단계, 이미지 3개 중 3개
    • Unplug the display cable located near the right display hinge by lifting the tape and pulling back.
  25. Dell Inspiron 15R 5537 DC Jack Replacement: 26 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 26 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement: 26 단계, 이미지 3개 중 3개
    • Remove the two 5mm Phillips #000 screws from the left and right hinges.
  26. Dell Inspiron 15R 5537 DC Jack Replacement: 27 단계, 이미지 2개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement: 27 단계, 이미지 2개 중 2개
    • Remove the display assembly by lifting the display from the hinges.
    • It is important to ensure the display cables are fully disconnected before removing the assembly.
  27. Dell Inspiron 15R 5537 DC Jack Replacement, DC Jack: 28 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 DC Jack Replacement, DC Jack: 28 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 DC Jack Replacement, DC Jack: 28 단계, 이미지 3개 중 3개
    • Remove the DC jack once the display is removed by pulling the cable assembly upwards.
결론
작성자
3다른 기여자 명과 함께
Ashton Floda
회원 가입일: 09/16/19
572 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 34
전체 시간: 996
