주요 콘텐츠로 건너뛰기
Dell Inspiron 15R 5537 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15R 5537 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15R 5537 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15R 5537 Keyboard Replacement: 2 단계, 이미지 3/3
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Dell Inspiron 15R 5537 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Dell Inspiron 15R 5537 Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 Keyboard Replacement: 4 단계, 이미지 1/3 Dell Inspiron 15R 5537 Keyboard Replacement: 4 단계, 이미지 2/3 Dell Inspiron 15R 5537 Keyboard Replacement: 4 단계, 이미지 3/3
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
결론
Ashton Floda
회원 가입일: 09/16/19
572 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 23
전체 시간: 981
