주요 콘텐츠로 건너뛰기
Dell Inspiron 15R 5537 Wi-Fi Module Replacement
필요한 것
  1. Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 2 단계, 이미지 3개 중 3개
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 4 단계, 이미지 3개 중 3개
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
  5. Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Wi-Fi Module: 5 단계, 이미지 1개 중 1개
    • Once the keyboard is removed, the Wi-Fi module will be accessible.
  6. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 6 단계, 이미지 2개 중 2개
    • Use the opening tool to lift both antenna cables upward from the Wi-Fi module.
  7. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 3mm Phillips #000 screw securing the Wi-Fi module.
    • Lift the Wi-Fi module up and out of the laptop.
결론
작성자
3다른 기여자 명과 함께
Ashton Floda
회원 가입일: 09/16/19
572 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 40
전체 시간: 1,108
