소개
Demonstrating step-by-step this guide will show you how to replace your hard drive.
필요한 것
Locate the RAM compartment and the screw on the right hand side. Remove the cover.
Turn laptop over and remove the bottom four screw covers outlined in red.
Then remove the three base screws.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Shoot! My Dell Inspiron 15R is different. Mine has an almost full length cover (11.6”) by 3” wide on the bottom. The hard drive and memory sticks are under that cover. I’m just not sure what else to remove to replace the drive with an SSD.
