주요 콘텐츠로 건너뛰기
Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement
필요한 것
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Sliding the Hard Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: 4 단계, 이미지 1개 중 1개
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Remove the Screws: 5 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Lifting the Hard-Drive Bracket: 6 단계, 이미지 1개 중 1개
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Align the Screw Holes: 7 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Replace the Screws: 8 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: 9 단계, 이미지 1개 중 1개
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: 10 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Replace the Screws: 11 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive assembly to the computer base.
결승점
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 35
전체 시간: 763
