소개
In this guide, we will be showing you how to remove and replace the Hard Drive.
필요한 것
Remove the screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, slide the hard-drive assembly toward the back of the computer to disconnect the hard-drive assembly from the connector on the system board.
Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
Using the pull-tab, slide the hard-drive assembly toward the front of the computer, to connect the hard-drive assembly to the connector on the system board.
Replace the screws that secure the hard-drive assembly to the computer base.
다른 한 분이 해당 안내서를 완성하였습니다.
