주요 콘텐츠로 건너뛰기
Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement
필요한 것
  1. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: 1 단계, 이미지 1/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: 1 단계, 이미지 2/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: 1 단계, 이미지 3/3
    • Flip the laptop over with the bottom facing up.
    • Pull the latches away from each other to release the battery.
    • Remove the battery.
  2. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 2 단계, 이미지 2/2
    • Throughout this guide, be sure to keep all screws in a safe place so they do not get lost. You should also keep them organized so they do not get mixed up.
    • Remove the 4 screws in the battery compartment using a 2.0mm magnetic phillips head screwdriver.
  3. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 3 단계, 이미지 1/2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 3 단계, 이미지 2/2
    • The screws do not come out of the access door. Do not try to remove them.
    • Loosen the 3 screws on the access door using the 2.0mm phillips head screwdriver.
    • Remove the access door.
  4. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 4 단계, 이미지 1/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 4 단계, 이미지 2/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 4 단계, 이미지 3/3
    • Remove the disk drive screw using the 2.0mm phillips head screwdriver.
    • Remove the disk drive from the laptop.
    • Remove the 2 screws under the disk drive with the 2.0mm phillips head screwdriver.
  5. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 5 단계, 이미지 1/2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 5 단계, 이미지 2/2
    • Remove the 4 hard drive screws using the 2.0mm phillips head screwdriver.
    • Pull the tab to remove the hard drive from the computer.
  6. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 6 단계, 이미지 1/1
    • Remove the 5 bottom base screws using the 2.0mm phillips head screwdriver.
  7. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 7 단계, 이미지 1/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 7 단계, 이미지 2/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 7 단계, 이미지 3/3
    • Depress the keyboard latches to release the keyboard with the 2.0mm flat head screwdriver.
    • Lift the keyboard up carefully.
    • Release the two ribbon cables underneath the keyboard.
  8. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 8 단계, 이미지 1/2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 8 단계, 이미지 2/2
    • Remove the 6 palm rest screws using the 2.0mm phillips head screwdriver.
    • Unplug the 3 ribbon cables.
  9. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 9 단계, 이미지 1/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 9 단계, 이미지 2/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 9 단계, 이미지 3/3
    • Take your time on this step and be careful to not break the plastic palm rest.
    • Separate the palm rest from the bottom base using the 2.0mm flat head screwdriver as a lever.
    • Unplug the ribbon cable underneath the palm rest.
  10. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 10 단계, 이미지 1/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 10 단계, 이미지 2/3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 10 단계, 이미지 3/3
    • Remove the 2 DC jack bracket screws with the 2.0mm phillips head screwdriver and remove the bracket.
    • Unplug and remove the old DC jack.
결론
Follow these instructions in reverse order to reassemble your device.
Allen Van Den Boom
회원 가입일: 09/29/17
109 평판
안내서 1개 작성함
Michigan Tech, Team S3-G1, Galliah Fall 2017 Michigan Tech, Team S3-G1, Galliah Fall 2017 회원
MTU-GALLIAH-F17S3G1
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 1,443
