주요 콘텐츠로 건너뛰기
Dell Inspiron 15z 5523 Memory Module Replacement
필요한 것
  1. Dell Inspiron 15z 5523 Memory Module Replacement, Loosen the Screw: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15z 5523 Memory Module Replacement, Lifting the Module Cover: 2 단계, 이미지 1개 중 1개
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15z 5523 Memory Module Replacement, Popping up the Memory Module: 3 단계, 이미지 1개 중 1개
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15z 5523 Memory Module Replacement, Sliding the Memory Module: 5 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  5. Dell Inspiron 15z 5523 Memory Module Replacement, Slide the Tabs: 6 단계, 이미지 1개 중 1개
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  6. Dell Inspiron 15z 5523 Memory Module Replacement, Tighten the Screw: 7 단계, 이미지 1개 중 1개
    • Tighten the captive screw that secures the memory-module cover to the computer base.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 246
