주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 16 7610 Back Case Replacement
필요한 것
  1. Dell Inspiron 16 7610 Back Case Replacement, Back Case: 1 단계, 이미지 2개 중 1개 Dell Inspiron 16 7610 Back Case Replacement, Back Case: 1 단계, 이미지 2개 중 2개
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16 7610 Back Case Replacement: 2 단계, 이미지 1개 중 1개
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
결론
작성자
4다른 기여자 명과 함께
Jerson Gomez
회원 가입일: 02/02/23
898 평판
안내서 3개를 작성함
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023 회원
GCC-PEE-S23S1G3
4 회원들
안내서 6개를 작성함
1가이드 댓글
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
Enos Nii Armah - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 54
전체 시간: 1,318
