주요 콘텐츠로 건너뛰기
Dell Inspiron 16-7610 RAM Replacement
필요한 것
  1. Dell Inspiron 16-7610 RAM Replacement, Back Case: 1 단계, 이미지 1/2 Dell Inspiron 16-7610 RAM Replacement, Back Case: 1 단계, 이미지 2/2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 RAM Replacement: 2 단계, 이미지 1/1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 RAM Replacement, RAM: 3 단계, 이미지 1/3 Dell Inspiron 16-7610 RAM Replacement, RAM: 3 단계, 이미지 2/3 Dell Inspiron 16-7610 RAM Replacement, RAM: 3 단계, 이미지 3/3
    • Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
    • Pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
    • Align your new RAM sticks on to the sockets when installing them to prevent any damage to the pins below.
결론
Michael Torres
회원 가입일: 02/02/23
145 평판
안내서 2개 작성하였습니다
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023 회원
GCC-PEE-S23S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 29
전체 시간: 335
