소개
If your touchpad is unresponsive to touch, finicky, or keeps powering on and off causing interruption, below is a guide on how to replace the touch screen
- Restart your Laptop
You can first try restarting your laptop. This may undo any memory issues that can lead to the touchpad not working on your Dell. If you have a mouse connected via USB or Bluetooth®, disconnect it before restarting your laptop.
If this doesn't work - the touchpad will NEED to be replaced.
필요한 것
Flip the device over, so the backside is facing up.
Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
Use a Phillips #00 to remove the five screws securing the battery to the laptop.
Pull the bundled cable away from the connector in the same direction as the wires are running.
Use both hands to life the battery up and remove it from the laptop.
After installing the new touchpad on the Dell Inspiron, retrace the previous steps to put the Dell Inspiron back together.
