주요 콘텐츠로 건너뛰기
Dell Inspiron 16-7610 Wi-Fi Card Replacement
필요한 것
  1. Dell Inspiron 16-7610 Wi-Fi Card Replacement, Back Case: 1 단계, 이미지 2개 중 1개 Dell Inspiron 16-7610 Wi-Fi Card Replacement, Back Case: 1 단계, 이미지 2개 중 2개
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Wi-Fi Card Replacement: 2 단계, 이미지 1개 중 1개
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 2개 중 1개 Dell Inspiron 16-7610 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
    • Lift the Wi-Fi card bracket off of the Wi-Fi card.
  4. Dell Inspiron 16-7610 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 16-7610 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    • Slide the Wi-Fi card from the slot to remove it from the device.
결론
작성자
6다른 기여자 명과 함께
Tristan Fairweather
회원 가입일: 02/02/23
94 평판
안내서 1개를 작성함
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023 회원
GCC-PEE-S23S1G3
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 250
