소개
In this guide, we will show you how to remove a Windows Hard Drive (SSD).
필요한 것
Using the Phillips screwdriver, unscrew the eight 5mm screws on the bottom of the laptop case.
Using a pry tool, pry open the case bottom starting at a front corner and working around the three sides.
Lift the case bottom from a corner, and completely remove the case bottom.
Unscrew the five 3mm screws holding the battery in place using a Phillips #00 screwdriver.
Using the pull tab, disconnect the battery from the system board. Remove the laptop once it is disconnected from the board.
Disconnect the speaker from the system board by pulling the plug.
Move speaker wires from under the tabs using pry tool or screwdriver. This will help to move the speaker away from the Windows drive.
Move the right speaker away from the laptop body to provide space around the Windows drive.
Unscrew the 5mm screw holding the drive using the Phillips #00 screwdriver.
Remove the Windows hard drive by raising the drive slightly and gently pulling from the system board.
