주요 콘텐츠로 건너뛰기
Dell Inspiron 17 Laptop Battery Replacement
필요한 것
  1. Dell Inspiron 17 Laptop Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before starting, make sure the laptop is powered off and disconnected from any power sources.
  2. Dell Inspiron 17 Laptop Battery Replacement: 2 단계, 이미지 1/1
    • Remove the Screws of the Laptop with help screwdriver.
    • There are 6 screws to remove. Make Sure to open the back of the laptop delicately.
  3. Dell Inspiron 17 Laptop Battery Replacement: 3 단계, 이미지 1/1
    • Carefully disconnect the old battery from the motherboard.
    • Gently remove the old battery from its housing by removing plug of battery.
  4. Dell Inspiron 17 Laptop Battery Replacement: 4 단계, 이미지 1/1
    • Insert the new battery into the housing.
    • Connect the new battery to the motherboard.
    • Securely reattach the battery back cover.
  5. Dell Inspiron 17 Laptop Battery Replacement: 5 단계, 이미지 1/1
    • Plug in the laptop and charge it to Full Capacity.
    • Power on the laptop and make sure it works with the new battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Anmol Desai
회원 가입일: 09/14/23
178 평판
안내서 1개 작성함
York University, Team 2-7, O'Regan Fall 2023 York University, Team 2-7, O'Regan Fall 2023 회원
YORK-O'REGAN-F23S2G7
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 57
30일 전: 281
전체 시간: 843
