주요 콘텐츠로 건너뛰기
Dell Inspiron 17 N7010 BIOS Battery Replacement
필요한 것
  1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove disc drive: 1 단계, 이미지 1/1
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 2 단계, 이미지 1/3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 2 단계, 이미지 2/3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 2 단계, 이미지 3/3
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove keyboard: 3 단계, 이미지 1/1
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
  4. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: 4 단계, 이미지 1/2 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: 4 단계, 이미지 2/2
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
  5. Dell Inspiron 17 N7010 BIOS Battery Replacement, Replace the cell: 5 단계, 이미지 1/1
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Joseph Sctbunio
회원 가입일: 09/23/17
7,416 평판
안내서 42개 작성하였습니다
댓글 7개
thanks for your help!!!
E P - 답글
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - 답글
Thanks for the instructions. Computer starts up great now.
jkleinjans - 답글
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 102
전체 시간: 18,145
