주요 콘텐츠로 건너뛰기
Dell Inspiron 17-3721 CMOS Battery Replacement
필요한 것
  1. Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: 1 단계, 이미지 1/3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: 1 단계, 이미지 2/3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: 1 단계, 이미지 3/3
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 CMOS Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-3721 CMOS Battery Replacement: 2 단계, 이미지 2/2
    • Remove the CMOS battery with the plastic opening tools.
    • Be careful while prying it open, the battery holder can break if you use too much force.
    • Do not use metal tools when touching anything that can have an electric charge.
결론
Christopher Meninno
회원 가입일: 03/20/18
296 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 963
