주요 콘텐츠로 건너뛰기
Dell Inspiron 17-3721 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 Hard Drive Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-3721 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the two 5.5 mm PH1 Phillips head screws holding in the hard drive.
    • Slide the hard drive out of its slot and lift it out of the device.
    • At the time of the creation of this guide, our device did not include a hard drive.
결론
Kevin Prairie
회원 가입일: 03/20/18
445 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 991
