주요 콘텐츠로 건너뛰기
Dell Inspiron 17-3721 Keyboard Replacement
필요한 것
  1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-3721 Keyboard Replacement: 2 단계, 이미지 2/2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin Prairie
회원 가입일: 03/20/18
445 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G3
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Wow that was easy! Thanks :D
Isaac Pettis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 414
