주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5748 Keyboard Replacement
필요한 것
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: 3 단계, 이미지 1/1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Inspiron 17-5748 Keyboard Replacement: 5 단계, 이미지 2/2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Inspiron 17-5748 Keyboard Replacement: 6 단계, 이미지 2/2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: 7 단계, 이미지 1/2 Dell Inspiron 17-5748 Keyboard Replacement: 7 단계, 이미지 2/2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
결론
Justine Vaca
회원 가입일: 02/12/18
121 평판
안내서 1개 작성함
Washington State, Team S2-G2, Lobnitz Spring 2018 Washington State, Team S2-G2, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S2G2
6 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 668
