주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5748 Speakers Replacement
필요한 것
  1. Dell Inspiron 17-5748 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Speakers Replacement: 2 단계, 이미지 1/1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Speakers Replacement: 3 단계, 이미지 1/1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Speakers Replacement, Speakers: 4 단계, 이미지 1/3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: 4 단계, 이미지 2/3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: 4 단계, 이미지 3/3
    • Remove the 4.5 mm Phillips #0 screw holding the Optical Drive in place.
    • Slide the Optical Drive out of the device.
  5. Dell Inspiron 17-5748 Speakers Replacement: 5 단계, 이미지 1/2 Dell Inspiron 17-5748 Speakers Replacement: 5 단계, 이미지 2/2
    • Remove the two 4.5 mm Phillips #0 screws on the access panel door.
  6. Dell Inspiron 17-5748 Speakers Replacement: 6 단계, 이미지 1/2 Dell Inspiron 17-5748 Speakers Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool, pry open the access panel, exposing the disk drive, RAM, and wireless module.
  7. Dell Inspiron 17-5748 Speakers Replacement: 7 단계, 이미지 1/3 Dell Inspiron 17-5748 Speakers Replacement: 7 단계, 이미지 2/3 Dell Inspiron 17-5748 Speakers Replacement: 7 단계, 이미지 3/3
    • Remove the 2.5 mm Phillips #0 screw securing the hard drive.
    • Slide the hard drive out using the pull tab.
    • Remove the hard drive from the device.
  8. Dell Inspiron 17-5748 Speakers Replacement: 8 단계, 이미지 1/1
    • Open the laptop and locate the keyboard.
  9. Dell Inspiron 17-5748 Speakers Replacement: 9 단계, 이미지 1/2 Dell Inspiron 17-5748 Speakers Replacement: 9 단계, 이미지 2/2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  10. Dell Inspiron 17-5748 Speakers Replacement: 10 단계, 이미지 1/2 Dell Inspiron 17-5748 Speakers Replacement: 10 단계, 이미지 2/2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  11. Dell Inspiron 17-5748 Speakers Replacement: 11 단계, 이미지 1/2 Dell Inspiron 17-5748 Speakers Replacement: 11 단계, 이미지 2/2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
  12. Dell Inspiron 17-5748 Speakers Replacement: 12 단계, 이미지 1/1
    • Remove the five 4.5 mm Phillips #0 screws found under the keyboard.
  13. Dell Inspiron 17-5748 Speakers Replacement: 13 단계, 이미지 1/3 Dell Inspiron 17-5748 Speakers Replacement: 13 단계, 이미지 2/3 Dell Inspiron 17-5748 Speakers Replacement: 13 단계, 이미지 3/3
    • Do not fully remove the palm rest until the ribbon cable underneath is detached.
    • Using a plastic opening tool, separate the plastic palm rest and partially lift the palm rest from the device.
    • Remove both ends of the ribbon cable. This can be done by flipping up the black tabs securing both ends.
    • Remove the palm rest from the device.
  14. Dell Inspiron 17-5748 Speakers Replacement: 14 단계, 이미지 1/3 Dell Inspiron 17-5748 Speakers Replacement: 14 단계, 이미지 2/3 Dell Inspiron 17-5748 Speakers Replacement: 14 단계, 이미지 3/3
    • Locate the first speaker.
    • Unplug the speaker cable.
  15. Dell Inspiron 17-5748 Speakers Replacement: 15 단계, 이미지 1/2 Dell Inspiron 17-5748 Speakers Replacement: 15 단계, 이미지 2/2
    • Lift the speaker from the corner.
    • Remove the speaker.
  16. Dell Inspiron 17-5748 Speakers Replacement: 16 단계, 이미지 1/2 Dell Inspiron 17-5748 Speakers Replacement: 16 단계, 이미지 2/2
    • Using the plastic opening tool, gently remove the second speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bradley
회원 가입일: 02/12/18
235 평판
안내서 1개 작성함
Washington State, Team S2-G2, Lobnitz Spring 2018 Washington State, Team S2-G2, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S2G2
6 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 529
