소개
If your Dell Inspiron 17-5749 keyboard is experiencing issues such as unresponsive keys, sticky buttons, or complete failure, this guide is designed to help you replace the keyboard with ease. Understanding these issues will guide you through the troubleshooting process and confirm that replacing the keyboard is the appropriate solution.
The keyboard is responsible for inputting commands and text into your laptop. A malfunctioning keyboard can disrupt your workflow and hinder the overall usability of your device.
For tips and precautions, follow proper procedures for disconnecting the power source and handling electronic components with ESD-safe tools. Wear an anti-static wrist strap or work in an uncarpeted area to prevent static shocks. The following link will direct you to a guide that provides the skills needed for use of an anti-static wrist strap: How to set up your Anti-static mat and wristband - iFixit Repair Guide.
필요한 것
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Turn off power to the laptop.
Unplug the charging cable from the laptop.
Turn the computer over and open the display as far as possible
Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
