주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5749 Keyboard Replacement
필요한 것
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 17-5749 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-5749 Keyboard Replacement: 2 단계, 이미지 2/2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: 4 단계, 이미지 1/1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
결론
Christopher Tran
회원 가입일: 02/13/18
1,161 평판
안내서 12개 작성하였습니다
Washington State, Team S1-G2, Lobnitz Spring 2018 Washington State, Team S1-G2, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S1G2
6 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 27
전체 시간: 453
