주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5749 Optical Drive Replacement
필요한 것
  1. Dell Inspiron 17-5749 Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 17-5749 Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Optical Drive Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-5749 Optical Drive Replacement: 2 단계, 이미지 2/2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/3 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 2/3 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3/3
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  4. Dell Inspiron 17-5749 Optical Drive Replacement: 4 단계, 이미지 1/3 Dell Inspiron 17-5749 Optical Drive Replacement: 4 단계, 이미지 2/3 Dell Inspiron 17-5749 Optical Drive Replacement: 4 단계, 이미지 3/3
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
결론
Christopher Tran
회원 가입일: 02/13/18
1,161 평판
안내서 12개 작성하였습니다
Washington State, Team S1-G2, Lobnitz Spring 2018 Washington State, Team S1-G2, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S1G2
6 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 10
전체 시간: 141
