주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5749 RAM Replacement
필요한 것
  1. Dell Inspiron 17-5749 RAM Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 17-5749 RAM Replacement, Battery: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-5749 RAM Replacement: 2 단계, 이미지 2/2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 RAM Replacement, Back Cover: 3 단계, 이미지 1/3 Dell Inspiron 17-5749 RAM Replacement, Back Cover: 3 단계, 이미지 2/3 Dell Inspiron 17-5749 RAM Replacement, Back Cover: 3 단계, 이미지 3/3
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 RAM Replacement, RAM: 4 단계, 이미지 1/2 Dell Inspiron 17-5749 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Using your fingertips, spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
    • Slide the memory module away from the memory-module slot.
    • When replacing the memory module, the securing clips DO NOT need to be adjusted. Simply slide the memory module in and gently press down on the elevated edge.
결론
Christopher Tran
회원 가입일: 02/13/18
1,161 평판
안내서 12개 작성하였습니다
Washington State, Team S1-G2, Lobnitz Spring 2018 Washington State, Team S1-G2, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S1G2
6 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 10
전체 시간: 343
