주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5755 Battery Replacement
  1. Dell Inspiron 17-5755 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-5755 Battery Replacement: 2 단계, 이미지 2/2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Battery Replacement: 3 단계, 이미지 1/1
    • Safely remove the battery from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Josh Bolan
회원 가입일: 02/15/17
140 평판
안내서 1개 작성함
USF Tampa, Team S6-G1, Lacy Spring 2017 USF Tampa, Team S6-G1, Lacy Spring 2017 회원
USFT-LACY-S17S6G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 819
