주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5755 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 17-5755 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 2개 Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 3개
    • Turn over your laptop and locate the two screws which secure the base cover.
    • Use a Phillips #0 screwdriver to unscrew the 8mm screws which secure the base cover.
  5. Dell Inspiron 17-5755 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
  6. Dell Inspiron 17-5755 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 17-5755 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Now with the base cover removed, you may lift it off of the laptop and continue.
  7. Dell Inspiron 17-5755 Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 Dell Inspiron 17-5755 Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the hard drive cable, and disconnect it from the laptop by lifting the latch which secures the cable.
  8. Dell Inspiron 17-5755 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
  9. Dell Inspiron 17-5755 Hard Drive Replacement: 9 단계, 이미지 3개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement: 9 단계, 이미지 3개 중 2개 Dell Inspiron 17-5755 Hard Drive Replacement: 9 단계, 이미지 3개 중 3개
    • Carefully remove the hard drive and its assembly from the laptop.
  10. Dell Inspiron 17-5755 Hard Drive Replacement: 10 단계, 이미지 3개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement: 10 단계, 이미지 3개 중 2개 Dell Inspiron 17-5755 Hard Drive Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the interposer by grabbing the black portion of the assembly, and pulling it away from the hard drive.
    • Be sure to not remove the interposer by pulling on the cable attached to it.
  11. Dell Inspiron 17-5755 Hard Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the four 4mm screws on either side of the hard drive assembly.
    • These screws are very small. Make sure not to misplace them.
  12. Dell Inspiron 17-5755 Hard Drive Replacement: 12 단계, 이미지 3개 중 1개 Dell Inspiron 17-5755 Hard Drive Replacement: 12 단계, 이미지 3개 중 2개 Dell Inspiron 17-5755 Hard Drive Replacement: 12 단계, 이미지 3개 중 3개
    • Safely remove the hard drive assembly from the hard drive to complete the process.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jeff
회원 가입일: 02/15/17
388 평판
안내서 3개를 작성함
USF Tampa, Team S6-G1, Lacy Spring 2017 USF Tampa, Team S6-G1, Lacy Spring 2017 회원
USFT-LACY-S17S6G1
3 회원들
안내서 5개를 작성함
2가이드 댓글
My question is, the hard drive is this a 7mm, 12mm or 15mm drive bay? I want to put a 4tb in my laptop but those are 15mm size and I can’t find what the size limit of the bay is.
Rachael Strange - 답글
I want to put a 4tb harddrive in my laptop.
Those only come in 15mm.
will this drive bay hold 15mm sized drives?
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 2,834
