주요 콘텐츠로 건너뛰기
Dell Inspiron 17-5755 Keyboard Replacement
필요한 것
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17-5755 Keyboard Replacement: 2 단계, 이미지 2/2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: 3 단계, 이미지 1/1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/2 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Inspiron 17-5755 Keyboard Replacement: 6 단계, 이미지 2/2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: 7 단계, 이미지 1/3 Dell Inspiron 17-5755 Keyboard Replacement: 7 단계, 이미지 2/3 Dell Inspiron 17-5755 Keyboard Replacement: 7 단계, 이미지 3/3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: 8 단계, 이미지 1/3 Dell Inspiron 17-5755 Keyboard Replacement: 8 단계, 이미지 2/3 Dell Inspiron 17-5755 Keyboard Replacement: 8 단계, 이미지 3/3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: 9 단계, 이미지 1/2 Dell Inspiron 17-5755 Keyboard Replacement: 9 단계, 이미지 2/2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gabriel Espinal
회원 가입일: 02/15/17
215 평판
안내서 1개 작성함
USF Tampa, Team S6-G1, Lacy Spring 2017 USF Tampa, Team S6-G1, Lacy Spring 2017 회원
USFT-LACY-S17S6G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 741
