소개
This guide will allow you to replace a defective motherboard for the Dell Inspiron 17-5755. Please ensure that the battery is removed before performing this replacement.
필요한 것
Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
Use a Phillips #0 screwdriver to unscrew the two 8mm screws which secure the base cover.
Use a Phillips #0 screwdriver to remove the 3mm screw which secures the optical-drive assembly to the computer base
Turn the computer over and using a plastic opening tool, push the optical-drive assembly out of the optical drive bay.
Afterwards, safely pull the optical-drive assembly out of the optical-drive bay.
다른 3명이 해당 안내서를 완성하였습니다.
