주요 콘텐츠로 건너뛰기
Dell Inspiron 17-7737 RAM Replacement
필요한 것
  1. Dell Inspiron 17-7737 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 RAM Replacement: 2 단계, 이미지 1/3 Dell Inspiron 17-7737 RAM Replacement: 2 단계, 이미지 2/3 Dell Inspiron 17-7737 RAM Replacement: 2 단계, 이미지 3/3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 RAM Replacement: 3 단계, 이미지 1/1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 RAM Replacement: 4 단계, 이미지 1/2 Dell Inspiron 17-7737 RAM Replacement: 4 단계, 이미지 2/2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 RAM Replacement, RAM: 5 단계, 이미지 1/3 Dell Inspiron 17-7737 RAM Replacement, RAM: 5 단계, 이미지 2/3 Dell Inspiron 17-7737 RAM Replacement, RAM: 5 단계, 이미지 3/3
    • Pry the memory module's cover off of the computer's base using an opening tool.
  6. Dell Inspiron 17-7737 RAM Replacement: 6 단계, 이미지 1/2 Dell Inspiron 17-7737 RAM Replacement: 6 단계, 이미지 2/2
    • Remove the 1st stick of memory by pushing the two lock pins to the side and pulling the stick out of the base.
  7. Dell Inspiron 17-7737 RAM Replacement: 7 단계, 이미지 1/2 Dell Inspiron 17-7737 RAM Replacement: 7 단계, 이미지 2/2
    • Remove the second RAM stick in the same fashion.
결론
Mark Batista
회원 가입일: 03/16/23
457 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G7
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 66
