주요 콘텐츠로 건너뛰기
Dell Inspiron 17-7746 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 17-7746 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Disconnect the Laptop from the AC adapter and turn off the Laptop.
  2. Dell Inspiron 17-7746 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Place laptop so the bottom faces up.
  3. Dell Inspiron 17-7746 Hard Drive Replacement: 3 단계, 이미지 1/3 Dell Inspiron 17-7746 Hard Drive Replacement: 3 단계, 이미지 2/3 Dell Inspiron 17-7746 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove the silver 15mm PH1 screw that holds the plastic cover in place over the battery.
    • Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
    • Place the screws accordingly because the length of the screws will matter when you reassemble.
  4. Dell Inspiron 17-7746 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Using a metal jimmy, pry up to remove the first half of the cover.
  5. Dell Inspiron 17-7746 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Apply pressure using your fingertips on the top of the cover, pushing to the front of the laptop. This will make the plate slide off exposing the hard drive.
  6. Dell Inspiron 17-7746 Hard Drive Replacement: 6 단계, 이미지 1/3 Dell Inspiron 17-7746 Hard Drive Replacement: 6 단계, 이미지 2/3 Dell Inspiron 17-7746 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the three black PH1 6mm screws that anchor the hard drive.
    • This screw hole will be empty because the 15mm silver screw that holds the plastic cover will anchor the hard drive down.
  7. Dell Inspiron 17-7746 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Using the Jimmy, pry up the hard drive and lift out using your fingers.
  8. Dell Inspiron 17-7746 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Gently wiggle and pull the connector to disconnect the Seta Cable attaching the hard drive to the laptop.
  9. Dell Inspiron 17-7746 Hard Drive Replacement: 9 단계, 이미지 1/3 Dell Inspiron 17-7746 Hard Drive Replacement: 9 단계, 이미지 2/3 Dell Inspiron 17-7746 Hard Drive Replacement: 9 단계, 이미지 3/3
    • Remove the harness around the hard drive by removing four black 4mm PH1 screws located on the side.
  10. Dell Inspiron 17-7746 Hard Drive Replacement: 10 단계, 이미지 1/1
    • Remove the hard drive from the harness.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joshua Plagerman
회원 가입일: 09/26/18
735 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 18
전체 시간: 1,284
