주요 콘텐츠로 건너뛰기
Dell Inspiron 17-7746 RAM Replacement
필요한 것
  1. Dell Inspiron 17-7746 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Disconnect the Laptop from the AC adapter and turn off the Laptop.
  2. Dell Inspiron 17-7746 RAM Replacement: 2 단계, 이미지 1/1
    • Place the laptop so the bottom faces up.
  3. Dell Inspiron 17-7746 RAM Replacement: 3 단계, 이미지 1/3 Dell Inspiron 17-7746 RAM Replacement: 3 단계, 이미지 2/3 Dell Inspiron 17-7746 RAM Replacement: 3 단계, 이미지 3/3
    • Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
    • Remove the silver 8mm screw that holds the plastic cover in place over the battery.
    • Keep these two screws together. Their size will matter when you reassemble.
  4. Dell Inspiron 17-7746 RAM Replacement: 4 단계, 이미지 1/1
    • Using the metal jimmy, pry up to remove the first half of the cover.
  5. Dell Inspiron 17-7746 RAM Replacement: 5 단계, 이미지 1/1
    • Apply pressure using your fingertips on the top of the cover and push toward the front of the laptop. This will make the plate slide off exposing the hard drive and battery.
  6. Dell Inspiron 17-7746 RAM Replacement: 6 단계, 이미지 1/1
    • Using the metal jimmy, remove the cover plate, this will expose the RAM.
  7. Dell Inspiron 17-7746 RAM Replacement: 7 단계, 이미지 1/2 Dell Inspiron 17-7746 RAM Replacement: 7 단계, 이미지 2/2
    • Apply outward pressure using fingers or a spudger on the small tabs on the RAM. Once freed the RAM will need to be lifted slightly, angling it upward, and then pulled out toward yourself.
결론
Joshua Plagerman
회원 가입일: 09/26/18
735 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 287
