주요 콘텐츠로 건너뛰기
Dell Inspiron 17" 7786 2-in-1 Fan Replacement
필요한 것
  1. Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Base Cover: 1 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Base Cover: 1 단계, 이미지 2/2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 2 단계, 이미지 2/2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 3 단계, 이미지 1/3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 3 단계, 이미지 2/3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 3 단계, 이미지 3/3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 4 단계, 이미지 1/3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 4 단계, 이미지 2/3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 4 단계, 이미지 3/3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Fan: 5 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Fan: 5 단계, 이미지 2/2
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 6 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 6 단계, 이미지 2/2
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 7 단계, 이미지 1/1
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 8 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: 8 단계, 이미지 2/2
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
결론
Delia Padilla
회원 가입일: 08/23/22
564 평판
안내서 5개 작성하였습니다
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 회원
GCC-CLASS-F22S1G3
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 27
전체 시간: 253
