주요 콘텐츠로 건너뛰기
Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement
필요한 것
  1. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement, Base Cover: 1 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement, Base Cover: 1 단계, 이미지 2/2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 2 단계, 이미지 2/2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 3 단계, 이미지 1/3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 3 단계, 이미지 2/3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 3 단계, 이미지 3/3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 4 단계, 이미지 1/3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 4 단계, 이미지 2/3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 4 단계, 이미지 3/3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement, Memory Modules (RAM): 5 단계, 이미지 1/1
    • Lift the cover to gain access to the memory module.
  6. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 6 단계, 이미지 1/2 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 6 단계, 이미지 2/2
    • Carefully open the securing clips on the end of each memory module slot until the module stick sticks up.
  7. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 7 단계, 이미지 1/3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 7 단계, 이미지 2/3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: 7 단계, 이미지 3/3
    • Remove the memory module by sliding it out of the slot.
결론
Delia Padilla
회원 가입일: 08/23/22
564 평판
안내서 5개 작성하였습니다
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 회원
GCC-CLASS-F22S1G3
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 128
