주요 콘텐츠로 건너뛰기
Dell Inspiron 1721 Back Cover Replacement
필요한 것
  1. Dell Inspiron 1721 Back Cover Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 1721 Back Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: 2 단계, 이미지 1/3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: 2 단계, 이미지 2/3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: 2 단계, 이미지 3/3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Back Cover Replacement, Display Assembly: 3 단계, 이미지 1/2 Dell Inspiron 1721 Back Cover Replacement, Display Assembly: 3 단계, 이미지 2/2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  4. Dell Inspiron 1721 Back Cover Replacement: 4 단계, 이미지 1/1
    • Disconnect the antenna connectors from the WLAN card.
  5. Dell Inspiron 1721 Back Cover Replacement: 5 단계, 이미지 1/3 Dell Inspiron 1721 Back Cover Replacement: 5 단계, 이미지 2/3 Dell Inspiron 1721 Back Cover Replacement: 5 단계, 이미지 3/3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  6. Dell Inspiron 1721 Back Cover Replacement: 6 단계, 이미지 1/3 Dell Inspiron 1721 Back Cover Replacement: 6 단계, 이미지 2/3 Dell Inspiron 1721 Back Cover Replacement: 6 단계, 이미지 3/3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  7. Dell Inspiron 1721 Back Cover Replacement: 7 단계, 이미지 1/2 Dell Inspiron 1721 Back Cover Replacement: 7 단계, 이미지 2/2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  8. Dell Inspiron 1721 Back Cover Replacement, Back Cover: 8 단계, 이미지 1/1
    • Disconnect the touch pad connector.
  9. Dell Inspiron 1721 Back Cover Replacement: 9 단계, 이미지 1/3 Dell Inspiron 1721 Back Cover Replacement: 9 단계, 이미지 2/3 Dell Inspiron 1721 Back Cover Replacement: 9 단계, 이미지 3/3
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
결론
Scott Nadeau
회원 가입일: 09/16/19
423 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 241
