주요 콘텐츠로 건너뛰기
Dell Inspiron 1721 DVD Drive Replacement
필요한 것
  1. Dell Inspiron 1721 DVD Drive Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 1721 DVD Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: 2 단계, 이미지 1/3 Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: 2 단계, 이미지 2/3 Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: 2 단계, 이미지 3/3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 DVD Drive Replacement, Keyboard: 3 단계, 이미지 1/3 Dell Inspiron 1721 DVD Drive Replacement, Keyboard: 3 단계, 이미지 2/3 Dell Inspiron 1721 DVD Drive Replacement, Keyboard: 3 단계, 이미지 3/3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 DVD Drive Replacement, Back Cover: 4 단계, 이미지 1/1
    • Disconnect the touch pad connector.
  5. Dell Inspiron 1721 DVD Drive Replacement: 5 단계, 이미지 1/3 Dell Inspiron 1721 DVD Drive Replacement: 5 단계, 이미지 2/3 Dell Inspiron 1721 DVD Drive Replacement: 5 단계, 이미지 3/3
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
  6. Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: 6 단계, 이미지 1/2 Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: 6 단계, 이미지 2/2
    • Grab the DVD drive and pull straight out from the side of the case to remove.
결론
Scott Nadeau
회원 가입일: 09/16/19
423 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 186
