주요 콘텐츠로 건너뛰기
Dell Inspiron 1721 Hinge Plate Cover Replacement
필요한 것
  1. Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: 2 단계, 이미지 1/3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: 2 단계, 이미지 2/3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: 2 단계, 이미지 3/3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
결론
Jason Haddox
회원 가입일: 09/04/19
424 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 157
