주요 콘텐츠로 건너뛰기
Dell Inspiron 1721 LCD Screen Replacement
필요한 것
  1. Dell Inspiron 1721 LCD Screen Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 1721 LCD Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: 2 단계, 이미지 1/3 Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: 2 단계, 이미지 2/3 Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: 2 단계, 이미지 3/3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 LCD Screen Replacement, Keyboard: 3 단계, 이미지 1/3 Dell Inspiron 1721 LCD Screen Replacement, Keyboard: 3 단계, 이미지 2/3 Dell Inspiron 1721 LCD Screen Replacement, Keyboard: 3 단계, 이미지 3/3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 LCD Screen Replacement, Display Assembly: 4 단계, 이미지 1/2 Dell Inspiron 1721 LCD Screen Replacement, Display Assembly: 4 단계, 이미지 2/2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  5. Dell Inspiron 1721 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Disconnect the antenna connectors from the WLAN card.
  6. Dell Inspiron 1721 LCD Screen Replacement: 6 단계, 이미지 1/3 Dell Inspiron 1721 LCD Screen Replacement: 6 단계, 이미지 2/3 Dell Inspiron 1721 LCD Screen Replacement: 6 단계, 이미지 3/3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  7. Dell Inspiron 1721 LCD Screen Replacement: 7 단계, 이미지 1/3 Dell Inspiron 1721 LCD Screen Replacement: 7 단계, 이미지 2/3 Dell Inspiron 1721 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  8. Dell Inspiron 1721 LCD Screen Replacement: 8 단계, 이미지 1/2 Dell Inspiron 1721 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  9. Dell Inspiron 1721 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 1/2 Dell Inspiron 1721 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 2/2
    • Remove the six Phillips #0 screws from the display case.
  10. Dell Inspiron 1721 LCD Screen Replacement: 10 단계, 이미지 1/3 Dell Inspiron 1721 LCD Screen Replacement: 10 단계, 이미지 2/3 Dell Inspiron 1721 LCD Screen Replacement: 10 단계, 이미지 3/3
    • Use an opening tool to remove the locks surrounding the display case.
  11. Dell Inspiron 1721 LCD Screen Replacement: 11 단계, 이미지 1/3 Dell Inspiron 1721 LCD Screen Replacement: 11 단계, 이미지 2/3 Dell Inspiron 1721 LCD Screen Replacement: 11 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the eight screws surrounding the LCD display inside the display case.
    • Lift the LCD display up out of the display case.
  12. Dell Inspiron 1721 LCD Screen Replacement: 12 단계, 이미지 1/1
    • Remove the display cable from the display case to completely disconnect the LCD display.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jason Haddox
회원 가입일: 09/04/19
424 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 258
