주요 콘텐츠로 건너뛰기
Dell Inspiron 1750 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 1750 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 1750 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Hard Drive Replacement: 2 단계, 이미지 1/2 Dell Inspiron 1750 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Remove the two 1mm double wide Phillips #00 screws.
    • Pull the hard drive away from the laptop.
  4. Dell Inspiron 1750 Hard Drive Replacement: 4 단계, 이미지 1/2 Dell Inspiron 1750 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Keep all screws in a safe place. You may need to use them for your new hard drive.
    • Remove the two #00 1mm screws on both sides of the hard drive.
    • Pull the hard drive cover away from the hard drive and set the cover aside.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tina Rickard
회원 가입일: 04/07/14
759 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 회원
CPSU-FORTE-S14S6G3
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 28
전체 시간: 9,502
