소개
Follow this guide if your disk drive is damaged and needs replacement.
필요한 것
Place the laptop on a flat stable surface.
Flip the laptop over so the underside is visible.
Remove the 2mm Phillips #00 screw next to the module cover.
Pull the disc drive away from the laptop.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
