주요 콘텐츠로 건너뛰기
Dell Inspiron 1750 Screen Replacement
필요한 것
  1. Dell Inspiron 1750 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 1750 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Screen Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1750 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Screen Replacement, Dell Inspiron 1750 Teardown: 3 단계, 이미지 1개 중 1개
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Screen Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 1750 Screen Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 1750 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Screen Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 1750 Screen Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 1750 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Screen Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 1750 Screen Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 1750 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Screen Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 1750 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Screen Replacement: 8 단계, 이미지 3개 중 1개 Dell Inspiron 1750 Screen Replacement: 8 단계, 이미지 3개 중 2개 Dell Inspiron 1750 Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
  9. Dell Inspiron 1750 Screen Replacement, Screen: 9 단계, 이미지 3개 중 1개 Dell Inspiron 1750 Screen Replacement, Screen: 9 단계, 이미지 3개 중 2개 Dell Inspiron 1750 Screen Replacement, Screen: 9 단계, 이미지 3개 중 3개
    • Use the spudger to lift the wires from their connections.
    • Remember to pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Flip the laptop over and pull the connections through until they are free from the laptop interior.
  10. Dell Inspiron 1750 Screen Replacement: 10 단계, 이미지 2개 중 1개 Dell Inspiron 1750 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two 2mm Phillips #0 screws from the screen hinges.
    • Lift the screen away from the laptop and gently set it down.
    • Put the rest of the laptop aside.
  11. Dell Inspiron 1750 Screen Replacement: 11 단계, 이미지 3개 중 1개 Dell Inspiron 1750 Screen Replacement: 11 단계, 이미지 3개 중 2개 Dell Inspiron 1750 Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to remove the plastic cover from the screen.
    • Remove the eight 2mm Phillips #0 screws from the corners of the screen.
    • Lift the screen away from the back panel.
  12. Dell Inspiron 1750 Screen Replacement: 12 단계, 이미지 2개 중 1개 Dell Inspiron 1750 Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the four 2mm Phillips #0 screws from the sides of the screen.
    • Remove the side railings from both sides of the screen by pulling the railings gently away from the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tina Rickard
회원 가입일: 04/07/14
759 평판
안내서 5개를 작성함
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 회원
CPSU-FORTE-S14S6G3
5 회원들
안내서 7개를 작성함
2가이드 댓글
Succeed ! Thanks.
Note: @ First opening, I add to do step 9 before the step 8. The antenna wire prevent you to "Gently lift off the top metal panel".
wxadha - 답글
My screen almost always has a pink spotty look. How do I know if I need to replace the screen, or just the wires?
Kathleen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 3,908
