소개
As its name implies, this component provides access to the hard drive and RAM, expediting further repair to the system.
필요한 것
Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
다른 한 분이 해당 안내서를 완성하였습니다.
