주요 콘텐츠로 건너뛰기
Dell Inspiron 17R-5721 Access Panel Replacement
필요한 것
  1. Dell Inspiron 17R-5721 Access Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 Access Panel Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17R-5721 Access Panel Replacement: 2 단계, 이미지 2/2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 Access Panel Replacement, Access Panel: 3 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • These two captive screws will loosen but will not separate from the panel.
  4. Dell Inspiron 17R-5721 Access Panel Replacement: 4 단계, 이미지 1/1
    • Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Lift off the access panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thomas Griffin
회원 가입일: 03/21/19
915 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team S2-G6, Bailey Spring 2019 UMass Dartmouth, Team S2-G6, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G6
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 195
