주요 콘텐츠로 건너뛰기
Dell Inspiron 17R-5721 Keyboard Replacement
필요한 것
  1. Dell Inspiron 17R-5721 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17R-5721 Keyboard Replacement: 2 단계, 이미지 2/2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Open the laptop to reveal the keyboard.
    • Using a plastic opening tool, pry the keyboard free from the palmrest assembly at the plastic tabs located across the top of the keyboard.
  4. Dell Inspiron 17R-5721 Keyboard Replacement: 4 단계, 이미지 1/1
    • Once free from the palmrest, flip over the keyboard.
    • Unplug the ribbon cable connecting the keyboard to the motherboard.
    • Remove the keyboard.
결론
Thomas Griffin
회원 가입일: 03/21/19
915 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team S2-G6, Bailey Spring 2019 UMass Dartmouth, Team S2-G6, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G6
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 310
